I'm trying this....here's a pic of somthing similar to how i'm designing mine, these are on a nissan sentra.
Mine is incorporating solid 3/4in steel rods that i'm getting drilled and tapped by a machinist, one side right hand thread, the other left hand thread. He used 1in tubular steel that he welded a nut on to each side. Also, i'm going to have my front support bracket connect the entire assembly together, connecting where the tow hook is attached to the frame on each side of the radiator support. This will stiffen the frame and chasis, as well as provide extra rigidity and strenth to the overall system.
Its gonna be beefy as hell, and all of the parts i'm using can be picked up at Lowe's(for the steel pieces) Ace Hardware(for the nuts bolts and spacers) and Grainger Industrial Supply(for the ball joint rod ends.)
All in all its prolly gonna cost me about $70 because for one i'm getting the rods machined, which isn't as cost effective as some other alternatives, but regardless, it will be much stronger than anything else. I'll have it done before friday, which is when i'm going to the track. I'll post some pics when i get it all fabbed up, and prolly post some times from the track.
