TomTom GPS Fix
geosho
I received an email from Tom Tom today saying they have a download for a GPS fix since my unit has been having issues with this. I did not solicit the email from Tom Tom, so apparently it must have resulted from my latest update of my SD card from my TomTom Nav1. I will try it and let the forum know if it fixes the problem. My unit has had 2 occasions over the past 3 weeks where the unit would not get a GPS fix on startup until about a half hour or so later or until the vehicle was shut down for an while. A quick shut off and startup of the vehicle did no good. We will see if the fix download cures the problem or not.
It's not a gps fix per se.
It's been available since tomtom home has existed.
it's a feature called gpsfix. fix as in the fixed location of the gps satellites. it's not a fix as in it fixes a problem/issue.
It's recommended you plug in your sd card to a computer and update the gpsfix file once a week. Why? because it will put a file on there that predicts where the satellites are in the sky so it can get a gps fix (connection) faster.
Thanks all. I downloaded it and we will see if it improves things. I'm sorry to see others are suffering the same issue.
