To rust proof or not, that is the question
BadgerMazda
2013 Mazda5
Hey All, I just bought a 2013 Mazda5 and have been thinking of having the bottom and side interior panels rustproofed. It is a one time cost of $300. Is this worth doing or not? Have the older models held up against rust?
I have an 06 "5", it was never proofed (originally delivered in NC but traded in in St Paul before it was a year old). It's lived 99% of it's life in MN/WI, driven year-round and maybe washed 3 times a year. it's nearly to 150K and the ONLY spot it's rusting is the bottom corner of the driver's door. And I think that only got rusty because the door drains got plugged with something (I used one of those fuzzy pipe-cleaners to open the drain holes back up when I realized the door was full of water)
THe 5's seem pretty good at holding up against the salt around here. If you wash your 5 more than my spouse did when she had ours I'm sure yours will hold up just fine.
I don't want to get into my "rust proofing rip-off rant" but after having multiple older cars where we live, without rust-proofing and not having an issue with them rusting out I don't see it as really worth the $. Just wash your car often and it'll live longer in the salt.
...Just wash your car often and it'll live longer in the salt.
Ditto. If you care for you car, you don’t need rust proofing. If you treat it as a bastard child, then it is worth considering. It also depends on your region. Does your county use a lot of salt or a mix solution? I looked into this a while back. Another debatable benefit is that the coating adds a thin layer of insulation from rock/road debris compare to the bare metal undercarriage. Makes logical sense but not sure how practical it works in the real world. Also, a proper undercarriage treatment request removing parts for thorough coverage =$. If it is a $300 job, it’s prob just an aero spay equivalent that you can buy and do yourself. Take the car to a car wash that offers undercarriage wash. Let dry and spray away. I do have a can of Wesley undercarriage spray that I shoot at certain joints.
Ditto. If you care for you car, you dont need rust proofing. If you treat it as a bastard child, then it is worth considering. It also depends on your region. Does your county use a lot of salt or a mix solution? I looked into this a while back. Another debatable benefit is that the coating adds a thin layer of insulation from rock/road debris compare to the bare metal undercarriage. Makes logical sense but not sure how practical it works in the real world. Also, a proper undercarriage treatment request removing parts for thorough coverage =$. If it is a $300 job, its prob just an aero spay equivalent that you can buy and do yourself. Take the car to a car wash that offers undercarriage wash. Let dry and spray away. I do have a can of Wesley undercarriage spray that I shoot at certain joints.
Thanks for the replies Gents, I am pretty particular about taking care of my autos, but I live in Wisconsin and they are now using that mix solution which I have heard is even worse than salt. That do it yourself with Wesley's may be a great option. Thanks again.
