I actually was THINKING about putting lowering springs on my 2007 mazdaspeed 3, but after my installer showed me my tires i was like what is causing this wear. And now I have stumbled onto this thread which is exactly what my tire shows. Geez what if you were doing 75 on the highway with your wife and kids in the car and this tire blows.
If you go out and look at your mazdaspeed 3, you can see in the front that the tire will wear on the shock bottom if you take corners hard. I know this because Costco moves the front tires to the BACK when you rotate, i work there. This proves there is a problem houston.
