Tire Wear
Yeah my Dealer also mentioned that The summer tires sold with the car were "designed" to only last about 20k miles. Which seems to be a consensus. I do really like my dealer they do seem to be very honest. Yeah I know a OXY MORON, but so far so good. Honestly I likes the season Potenzas were a great tire, maybe still go with a Summer set and a winter set. Sport cars require special treatments.
10,700 on mine replacing them in the spring time... they started wearing badly after about 6,000 ive been to the track twice but still.. im putting somt toyo's on a set of nice blacked out rims..
I got about 15k gout of mine. I changed them to Pirelli M+S jsut befor hte winter snow hit.
They are soft tires, "ultra high performance summer times" according to tire rack.
Its just a price you pay for getting these kinds of tires straight from the factory. They were fun for a year, now its time for the good all seasons.
I burned up a set of almost new RX-8 Bridgestones in about 15,000. I'm on a nice set of Proxes so we'll see how these hold up.
you need to rotate these tires regularly!! I need to get my car aligned I think but I mainly make right turns. So the out side of my left front wore pretty bad. But it is an all wheel drive car and they say that they must be rotated more often. I go by how they look not by miles. And I have softer than stock tires too. SO that may have something to do with it....
Maybe we should be reporting excessive tire wear to Mazda
(RTM) ...remember that you bought a fairly high performance vehicle. It did not come from the factory with wimpy all season tires with a treadwear of 440. I believe the treadwear on the Potenzas is 140...i could be wrong,..but I know it is very low. It's a soft compound summer tire. Same thing happened with the stock tires on the MSP's.
There are decent performance tires out there with treadwear in the 300 range. Tirerack and discounttiredirect shows the specs of tires online.
There is nothing wrong with your tires. As a previous Toyota service manager I heard that complaint many many times from new car owners. Especially those buying a car like the camry se v6. Those buying a camry are not looking for performance tires but from the factory they were coming with a fairly soft compound. 15K miles into the car they would start complaining when they needed new tires.
Bottom line,...you are lucky to be driving a MS6! Now go buy a longer life performance tire. :-)
My experience tells me that the writer quoted above is correct in that there is nothing wrong with the tires, but I disagree with his contention that buying tires with a high treadwear number is the answer. I believe that there is something mis-engineered with the front suspension of the Speed6. I have read that a camber adjustment could cure the problem of uneven and premature tire wear, but the camber is not adjustable; however, I don't know how accurate that report is.
As for my experience, a month after I bought my Speed6 in November 2006, I was in a light snow and (despite my dealer's testimony when I questioned why Mazda would sell a car in Pennsylvania with only summer tires) I found the "stock" summer performance tires to be totally unsafe. At that point, I installed Pirelli P-Zero Nero Mud and Snows, rated at 400. By the time they had 15,000 miles on them, they were worn to the point that they would not pass a PA state inspection.
At 5,000 miles, I took the car to the dealer believing that the front end was way out of whack because the outside edges of the front tires were cupping badly and the inside edges wearing noticeably. The dealer was alarmed enough to check the alignment--free. The report came back that all was in spec, and the dealer rotated the tires front to rear and added two pounds of pressure. At about 12,000 the "new fronts" were not cupping as badly as the originals, but still wearing alarmingly quickly, so I visited the dealer again. Once again the service manager was concerned enough to re-check the alignment--again free, so you know they had to figure that something was wrong with my car!--and it came out fine again. I made a third visit a couple of weeks ago with the tires worn beyond inspection standards, and I was basically told that I have a performance car with performance tires, what did I expect? Rotate them with each oil change, and GO AWAY.
The change in attitude makes me believe that, as Mazda dealerships are becoming more familiar with the cars and getting a parade of them coming in for the same reason, they are coming to realize that this is a common condition and unfixable.
If you go to Tire Rack web site and check the reviews, you'll see that people are getting in excess of 60,000 miles out of these Pirellis, and one of the guys I work with has a Lexus 300 with 50,000 miles on his P-Zero Nero M&S's, so it's not the tires. I don't drive overly hard. I put two sets of replacement tires (one at about 40,000 miles and another at 90,000) on my last car, a Nissan Maxima, and sold it at 130,000 miles with plenty of tread on the tires, so I don't think it's me. That leaves only the car.
I really love the Speed6, but I won't put up with putting tires on it every 15-20,000 miles. I'm going to give it one more shot with a harder Yokohama Avid H4s (500 wear rating) and, if these don't last more than 20,000 miles, I'm going to put the almost unused summer tires back on it and trade it.
Perhaps everyone with this problem should call Mazda at 800-222-5500 and complain. If you do, have your VIN and other pertinent info handy.
My tires usually last 15k miles. Is any1 having problems with all the tires edges being cupped? Like high and lows. Inside and out. Center is perfect.
Holy old thread batman!
Qwik mine wear like that also, i think tire wear has a lot to do with the complicated AWD our car has. I've got a set of fuzions that have lasted 20k miles so far, probably won't last to much longer though.
Try TireRack for Kumho Ecsta SPT. I'm going to try those. $100, rate close to the micheline pilot sports and some of the miata guys have used them and say they are getting over 30k on them.
