Tire question
mzballin
alright so i have a normal mz3 hatchback.. and im about to get the OEM first gen ms3 wheels and i just wanna make sure that these tires will fit..
im told that the OEM tire is 215/45/18 so obviously thatll work.. but im also told that the
235/45/18 will fit??? yes or no?
lemme know.. thanks alot!
Do you still need to get the tires? If so, why are you going for anything other than oem?
Chances are its going to screw with your speedo either way. But for the stock ms3, in order to get the least difference with the speedo from 215/45 the next size up is 225/40
