Stolen from another article:
Beginning in model year 2013, some Mazda vehicles are equipped with a tire
pressure monitoring system that does not use wheel mounted sensors.
Instead, the new sensor-less system uses an advanced ABS system to indirectly monitor the
affect of under inflated tires. Under inflation is detected by monitoring tire rotational
behavior using advanced signal processing spectrum analysis.
If a tire looses pressure, (or for some reason becomes over inflated,) its expected
rotational characteristics will change. This change from what’s expected is then
assumed to be under inflation.
The TPMS malfunction indicator lamp (MIL) will then illuminate.
After any type of tire or wheel maintenance, (for example adjusting tire pressure, tire
rotation, tire/wheel repair or replacement), the system must be reset. Additionally,
after battery discharge/disconnection or ABS/ABS related system diagnosis or repair,
This is accomplished using a TPMS Reset Button located on the dashboard of the vehicle.
