ok, so here is what you do to find the leak, it does pretty much sound like an intake leak like mentioned before. Start you car, get someone to rev it up a little, have one of thoes scented sticks, or anything that makes visible smoke, and go arround your intake area and see if the smoke gets drawn anywhere it's not supose too.. this will only work in a garage or on a day with no wind mind you.. and even then it's tricky, but when you do find the leak it will be quite visible as the smoke will go straight for it.
a cigaret also works very well hahahaa.. or a joint... but then, you're waisting man.
is the egr open/being used at throttle?
apparently its open during throttle and closed during idle
Also, there aren't actually 500 yellow MP3's. The first 1000 were blue and the remaining 500 are scattered blue or yellow. So it's even more rare than you thought!2 of the original 500
So did you figure out the high idle problem and now you're just trying to pinpoint the vac leak sound? Did you adjust the actual cable?
I have not figured out the high idle thing yet. I did get the CEL again. Idle seems to be fine tho. I have not adjusted the cable
