you should NEVER adjust the TAS screw, ONLY the AAS screw... that's why your idle is still ****** up, or you have a vacuum leaki figured out how to adjust the cable. i adjusted it so that the throttle plate was completely closed, however the car would not idle. I would start the car and it would stall out immediately. I adjusted the TAS screw a little bit to open they plate and now it will idle. Is the plate suppose to be completely closed? What i've read across the internet says the plate should be open just a little bit at idle
