Something to be aware of: Depending on your state and therefore the design of the plate itself, you may or may not want a thick bottom bezel. Some are a lot wider and can impede on the words. e.g. the California one requires somewhat of a thinner frame style vs the wide type.
NY State reg says no part of the plate may be obscured. 99 times out of 100 the thicker bottom will not cause a problem but occasionally you'll get a summons for the thicker bottom, especially in NYC.
That's why I went with this type from Amazon. It has a clear cover helping to keep the plate clean.
https://www.amazon.com/dp/ (commissions earned)
