Not bad for a car from the 90s with 200k+ on it. I never seem to get more than 28 in any of my cars. Must be the limit for 75-90 highway cruising with 4 cylinders lol. On the flip side, they all get 14-15mpg on track.haha Car people are tools... But I will try the adjustment on the trany if not I'll get a replacement. I am happy with the car it has a 12.5 gal tank and I go 380 miles on it and average 35 mpg and cost $25 to fill up
For the amount of Meth that I'm spraying it would be to much but keep in mind I'm running two nozzles.I was going to have mine come on at 5psi and full spray by 10. is that to early?
I was but the E content has already started to go down to winter blend (started back in october). Right now I'm on my safer 93 tune until the summer blend E85 is back. I haven't had a chance to nail down any good logs for VD lately. My baseline before the FMIC and meth was in the 280-290hp range when I left off on my 93 tune with a stock TMIC.John, are you running e85 in addition to spraying meth?
Also, what kind of power are you seeing on vdyno?
It really depends on his intentions. Now that hes wanting to still run E I would say yes. If he was going to stick with meth only for cooling and fuel I would say start around 8-10psi with full coming on by 17-18psi and if that doesn't do enough step it down 2psi at a time as needed depending on the logs.
when I need to use it for fuel I am thinking about tapping the intake manifold with 4 nozzles and injectors.
save a little money and get a few parts for the miata.
Isn't that an oxymoron?![]()
Edit: And to all you people paying low insurance... EFF off
and now I'm officially old for using the phrase "when I was your age"
As long as you don't let the nozzles get clogged the dye isn't an issue. Even the Boost juice has dye, the issue is more the detergent which can be combated by running a bottle of "Heet" (straight meth) every so often mixed in with your washer fluid. Although this is based off of the blue fluid, not sure how your green with the extra detergents will fair.Thanks it will be used as a supplemental fueling source soon. But as of now it will just be a cooling and cleaning source. I will be running 1 nozzle for now but when I need to use it for fuel I am thinking about tapping the intake manifold with 4 nozzles and injectors. Also I think at that point I will need to be running meth without dies and bug flavoring
won't you be better off with the new cp-e intake manifold?
