Swapped the motor in the MS6 this weekend. HUGE thank you to Jake, V, Dave and Pablo for all the help!
We finally got her wrapped up today. Went to fire it up and sounded like the starter died. Jake found a loose ground wire for the oil pressure sensor, tightened it down and she fired up. Took her around the block and everything feels good. So many vibes from the AWR motor mounts, balance shaft delete and light weight flywheel but I don't mind. So happy and relived she's back together now. Jake adjusted the map a little for the downpipe and now I just gotta drive like an old man while breaking in the new motor and clutch.
