We should probably start a new thread for this...
Quick question. If I don't have my OEM steering wheel with airbag in do I need a harness? If so I might have to keep it around until then.
No you can use any steering wheel you want. And anyone with a harness should have the airbag disconnected or fuse pulled.Quick question. If I don't have my OEM steering wheel with airbag in do I need a harness? If so I might have to keep it around until then.
Is Pablo going to be bringing his new car? Test and tune eh?
Open for flaming here but why do you need to disconnect the air bag with a harness?
Peaches, did you get my text about the axles? I have spares.
Yeah, unfortunatelly it's not going to be until last Summer at the absolute earliest! I still don't have my exhaust manifold (so no exhaust), I won't be able to do any fiberglass work until late Spring (so no fan shroud), and even once everything's put together I'll still need to break in the engine for like 2,000 miles (new bearings and stuff)Jon, you don't think you'll be done by June? No rush of course, but that's 5 months away. Even my slow ass should be done by then. haha
Bone stock. I've wanted to play with it for a while but I keep telling myself all time/money goes to the RX-7. The rear end wobbles too much for my liking. I feel like snap oversteer will turn into snap oversteer + rollover in the 2. But if your's did well fairly stock maybe I'll be able to convince myself. I feel like I should at least upgrade the front pads to HPS's or something though. Maybe I'd be able to sneak in the Corksport rear bar... DAMNIT!Blasphemy! It's stock? It won't scare ya. If anything if you take a corner too fast it will just understeeeeeeer. I had a ton of fun in the 2. Reid (?) Kryder of Kryder Racing took mine around Nelson and said it was a great car, just needed a slightly stiffer suspension. It really was a blast on the track![]()
What Will said is part of it, but the more practical reason for it is that in most crashes you wind up with a torn up dash, smashed windshield, maybe hurt thumbs and the driver doesn't get anywhere near the airbag. I've seen offs where the airbag damage is much worse than the actual crash damage. With a properly installed and worn harness, you should never get anywhere near hitting your head or torso on the steering wheel.Open for flaming here but why do you need to disconnect the air bag with a harness?
I do have more vacation than I know what to do with this year so maybe a week at Mid-Ohio is a good idea.
