The nasty on sub installs
coreyt72
2007 Mazda CX-7
I have been through just about all of the posts about installing a sub on a factory Bose system and it seems that everyone agrees to disagree.
What I have done so far is to connect my line converter to the speaker wires coming out of the Bose amp, (using the wiring schematics found on this site...thanks fella's!) connected my amp with RCA cables and then the sub.---It did not work!!! I checked all of my connections (12v Con, remote, ground and line conv connections) and double checked them again and nothing. The amp gets power but, either no input signal or output.
Has anyone here succesfully integrated an additional amp and sub to a factory Bose system or is it a lost cause?
Corey
Nevermind...after triple checking my work and not being rushed...I figured out that I was using a speaker + as my remote amp lead instead of following the schematics(hand)!
Anyway I am up and running! Now on to bigger and better stuff like LED turn signals on the side mirrors!
corey
Can u help me with the wiring info and how do I get to the speaker wires... I have a non BOSE unit.
Thanks
