yup. had them for about a year and about four track events. performance wise i have been completely satisfied, they do great on the track. coilovers are not meant for DD comfort so i can't really complain about that. just make sure you have a good chiropractor if you plan to drive on bumpy roads! had BCs on my MSP which were stiffer than my current setup even on the softest setting. don't know if the BCs for the MS3 are comparable. i was on the fence between BCs and H&Rs for my MS3, but went with the H&Rs since i had some small build quality issues with my previous set of BCs.
Thanks. I am still undecided--hopefully my decision will be made tomorrow by the time I place an order, LOL. Probably should take this to PM, but here is my thinking:
1. BC Coilovers ($1000)-Height and Damper adjustable, stiff, built for more heavy track use---build quality issues???
2. HR Coilovers ($1100)-Height Adjustable only, not as stiff, progressive springs for easy DD ride, yet good on track. However progressive springs can be somewhat unpredictable compared to a spring that will react the same regardless of the load.---build quality will be much more reliable???
I am a "go big or go home" kind of guy. The car will see minimal track time, but some every year. Mainly a DD, 70k miles. I don't mind a harsh ride, and at first I thought damper adjustments were a 'have to have.' Now I am not so sure... Anyways, we will see what happens tomorrow, but any last minute ideas and experiences to help my decision will be greatly appreciated! Thanks!
im using plastic plugs from home depot. found in the fastners section. i sanded them smooth and used touch up paint to paint them. two of the big holes are 3/4" one is 11/16" and im having a hard time with the smaller holes. im thinking its gonna be the 1/4" ones. and for the square holes. i have no clue. lol ill snap a photo tomorrowJdowden, what did you use to fill the holes or did you swap trunks?
Does anyone have or have insight on the yellow speed coilovers? They could be the only thing between me and some bc's.
