- 2016 CX-5 GT AWD Tech/iAct
anyone got a picture of how is the reverse light output when replaced by led? Is it easy to change the bulbs for reverse lights?
OEMs:
https://www.amazon.com (commissions earned)
I played with the pictures to try and make them look like they did to my eye.
It is much easier to back into my driveway now (culvert on one side, mailbox and fence on the other, very dark).
Changing the lamp is very easy, use a plastic spudger (or small screwdriver with thin clothe wrapped around the tip) to pop the small plastic panel off of the inside of the rear hatch.
Then remove the lamp & socket (1/4 turn counter-clockwise), pull the lamp out of the socket and replace it with the LED, test before reinstalling the socket into the reflector, (50% chance you get it right the first time).
If it works, reinstall the socket into the reflector, if not, flip the LED 180 degrees in the socket.
