jam_asian85
- Mazdaspeed 3
save the $39.05 and get the corksport
save the $39.05 and get the corksport![]()
is there a difference between a race pipe, and a test pipe?
am i going to trip a CEL with a CS test pipe and a MS cbe?
Don't see how it could. Your sensors are on the 1st cat and that's where all the issues seem to arise.
regardless of throwing a CEL, by putting in a testpipe arent you replacing what is called the "cleanup cat" in which if you tried to get a smog test where they put the meter into the back fo teh exthaust pipe it will at that poitn register thare is no secons cat as its measuring from behind where the testpipe/second cat would be?
