I pull a 700lb. teardrop trailer with both a 2014 and 2016 Touring AWD (2.5l engine). The only modification I made was to install a Curt trailer hitch (and wiring). Works great.Hello,
I would like to know if somebody of you pulls a tent trailer with your cx5 and what is the update you made on your cx5 to make it.
thank you very much
Hello,
thank you very much
Not sure, had the hitch installed with 4 pin connector, then realized I would most likely need the trailer brake based on my expected use. Just started my research... Will let you know, when I get more info/ recommendations.thank all for the info im also interested with your question edj_03
and does the 4 pin flat harness wiring work with trailer brake?
Which wiring adapter did you use on the 2016? Looking into adding a hitch to my 16 but was unsure which lighting adapter would work.
