TCE big brake kit installed
Airman Jack said:
so the MINIMUM wheel size you'd need is 18 inches... methinks that's a little impractical for canadian winters :(
if you're spending $3000 on brakes.. spend another $1000 and get a winter beater (homework)
Hey who's interested in maybe doing a group buy? I have gotten a few people together on this before who's interested? Put your name down.
vindication said:
what series tire does one use on a stock 3 wheel? and on a 19?
If you stay with the same 205mm section width:
17" 50-series
18" 45-series
19" 40-series
Most people have been going to a 225 section width, though:
17" 45-series
18" 40 series
19" 35-series
Man... you people keep pushing that price higher and higher!
According to a post ssinstaller made on another thread, it's $1750-ish, not $3000!
hahaha. my bad.. i had no idea what the cost was for the 3.
and i was referring to cdn $$.
the KVR bigbrakes are $2400+tx... i was just assuming that a newer brake system for a newer car would be more $$.
my bad
Ahhhh... now that would make a difference. Only to about $2200cdn, though.
(canada)
Do the stock 17" wheels clear the caliper or do you have to go with 18" if you use these brakes?
Mikey444 said:
Do the stock 17" wheels clear the caliper or do you have to go with 18" id you use these brakes?
Ahem...
ssinstaller said:
The front brakes don't even fit with the stock 17" wheels, there is no way they would clear a 16" wheel. My 19" wheels clear outside edge the calpier and rotors just fine, but there is only about 3/16 of an inch between the rim spokes and the caliper front.
As my dad used to say, "If you can't keep up, take notes." :D
