Have you ever ran LT tires on a >5000lb vehicle? You are absolutely correct in terms of achieving the same engineered load capabilities... But that doesn't mean the tires will suddenly blow if you run lower PSI. In fact its quite common to run 20-30 PSI or even lower (in certain conditions) on LT tires. Some guys even do it with 7000+ lb rigs. The tires will be just fine.I want to let it go, but my personal code of professional ethics demanded that I do the math.
The placard pressure on a CX-5 with 17” wheels is 34 psi. If you consult a load-inflation table it will give you a load of 1746 lbs at that pressure. Following the P-metric to LT-metric conversion on page 11 of that document, you remove the 10% de-rating from running a P-metric tire on a “tall” vehicle, and you get 1587 lbs load requirement for each tire. Look up the pressure/load numbers for a LT225/70R17 tire on page 25, and you see that for single-tire applications, the next higher load than 1587 is 1640, and you get that at 40 psi inflation pressure.
I can go into why the R speed rating is also grossly inadequate, but I can already see “I’m never going to go 106…” on the screen so I won’t bother.
I think leeharvey was pointing out that to be at the same performance/safety stats, the tires you just bought need to be ran at 40 PSI. And that combined with the stiff sidewall will feel like you are running wooden wagon wheels lol.I honestly don't understand what you are saying.
Sure - follow the advice of some schmoe on a forum over actual technical specifications of tire manufacturers, just because it fits what you already wanted to do.That I understand. Thank you. That is how I was thinking it should be.
And I’d be perfectly willing to call the people doing it “dangerous and stupid” to their faces. They’re the same people who post pictures of heat cracking, and then blame it on parking in the sun.In fact its quite common to run 20-30 PSI or even lower (in certain conditions) on LT tires.
Good god. I am still trying to wrap my head around all of this.I'm not worried about handling, accurate mph, etc
It seems many people who ask for advice online, don’t really want advice to guide them. They are seeking affirmation for what they are going to do regardless.
I personally like to get a reasonable life span out of my tires. Regular rotations, monitoring for uneven wear, regular pressure checks. Once I dont feel comfortable driving on them at highway speeds in very wet conditions any more, time to replace.It seems many people who ask for advice online, don’t really want advice to guide them. They are seeking affirmation for what they are going to do regardless.
I take my tires very seriously… only purchasing proper quality tires, keeping them correctly inflated, and replacing them well before the tread reaches minimum depth. Not only is your personal safety riding on your tires, the safety of your fellow drivers are as well. If you lose control on wet pavement, you could hit someone, which could give them a life-changing cervical (neck) injury… or worse.
Just a quick FYI for everyone...Friendly debates and discussions are okay but not when they turn into arguments or worse...Please keep it friendly, thanks.
Exactly, thanks @sm1ke ...Unfortunately, this is now the second time we've had to post a reminder in this thread as I posted something similar (added above)..Two reminders is not a positive trend.Hey guys, just a reminder to keep the conversation civil. It's perfectly fine to disagree and debate on best practices and question recommendations given by other members - the discussion is how a lot of us learn and decide which approach to take. What's unnecessary is being condescending or resorting to name-calling in your replies. Keep it friendly, constructive, and informative.
Thanks
