I want to let it go, but my personal code of professional ethics demanded that I do the math.
The placard pressure on a CX-5 with 17” wheels is 34 psi. If you consult a
load-inflation table it will give you a load of 1746 lbs at that pressure. Following the P-metric to LT-metric conversion on page 11 of that document, you remove the 10% de-rating from running a P-metric tire on a “tall” vehicle, and you get 1587 lbs load requirement for each tire. Look up the pressure/load numbers for a LT225/70R17 tire on page 25, and you see that for single-tire applications, the next higher load than 1587 is 1640, and you get that at 40 psi inflation pressure.
I can go into why the R speed rating is also grossly inadequate, but I can already see “I’m never going to go 106…” on the screen so I won’t bother.
