Hey GAXIBM can you take a picture of your CX-5 front view. Just want to see what you got there. And where u got those cover?
If I lived in the cold north, I would block at least half of the radiator airflow for the winter season when you put on winter tires. If you notice the front of long haul trucks you will often see plastic covers over most of the radiator in winter weather and they have a large engine, but it works better if the coolant does not get so cold. It also improves mileage as do active shutters which a lot of trucks and new cars (new Mazda 3 top trim) now have.
Just a tip, for aerodynamic reasons you want to block the top off first and go lower as you need more. Also, without a gauge to watch actual coolant temps I'd be wary of doing the blockoff since modern-day stock needles have a quite large dead spot to reduce the visual movement and prevent panicking for those that don't know any better.
So just beware, if the needle moved higher than normal, the water temp is not just a little higher than it should be, it's a LOT higher. Center dead spot is probably a 40degree range.
This topic seems odd to me. The car takes a little longer to warm up than our other car and past cars (a Trailblazer and a Dakota) but that always made sense to me (as was previously pointed out its a small 4 cylinder). What my wife and I have both noticed however is just how much warmer it is once warmed up. We live in Wisconsin, not quite as consistently cold as the Canadians but still darn cold, and we normally run the thermostat at the 12 o'clock position or else its too hot in the car. The Trailblazer we have and the Dakota we used to have would require 3/4 or full heat for a far longer drive time to keep us warm on the coldest days. I'm sure the CX-5 is sealed up much tighter than either of those trucks but it's more than just that, the air out of the vent is noticeably warmer. I've always assumed the difference is a more efficient design in the Mazda (providing more cabin heat with less engine supplied heat). So it's odd to me that people would mention the car doesn't warm up since that is completely opposite of my experience. It would be interesting if a few of us took thermometers to the vent and posted the results (along with run time and outside air temp). That way we could rule out our individual perception of heat and look at it a little scientifically. I wonder if we'd find that different models or years don't warm up as nicely.
Sorry, not buying it. My girlfriend's 4 cylinder Subaru has blasting hot heat within 5 minutes or so, and my stepson's Saturn also has no problems like my CX-5 does.All, please realize this is a small 4 cylinder engine. I've owned dozens of cars including a used car dealer in IL. Similar to other small displacement Japanese cars (i.e. Honda) they take a while to heat the heater core and never blow super hot air, period. Deal with it or go buy a V6 or V8 something or premium vehicle.
