Aberration
- 2001 ES Proteg
OK I have some questions about how to go I have a pioneer head unit works fine ect. I'm an infinity fan and looking at the 6.5 component systems
Kappa perfect 6.5 RMS 100@4ohms
Kappa 6.5 RMS 90@2ohms
1st question is deciding between the 2 speakers as perfects are 1.5 times the price, not using rear speakers yet so thinking powering them is going to be the deciding factor
2nd is do I go with a 4 channel to run the doors then bridge for a woofer in back or do I go with a 2 channel and a mono? if I go for the 2 amp set up is there going to be enough power to run it?
mock ideas
4 channel with 100 x 2 @2 for the front sending rest (200 @4) to a sub
2 channel either using 2 or 4 ohm based on the speaker and around 500 mono @2ohms to a sub (am I going to be dimming too much with this?)
Thanks for any help just weighing some options (hi)
other things... I have a 2001ES and listen to everything, price is always an issue but for the sake of argument any budget
mock ideas
