Synchronic BOV
Its not really an increase in "power". Its simply fixing a boost leak and regaining the power you lost thanks to the leaky stock BPV.
I picks up really good power. Holds about 3psi more at 6k. Thats where the power comes from. Read my thread. It works sick. Hit up ken at pg, thats where I got mine.
Any idea what these will sell for? Also, how easy/difficult was the installation, for someone that doesn't have a lot of mechanical prowess. A video demonstrating the installation would be great if anyone has one.
it is very simple. pretty much 2 screws for the engine cover, 2 screws to get the stock BPV off and remove the 2 hoses going to it. from protegegarage, it think its about $200.
mazpro.....have you also installed one of these? If so have you experienced the same increases......worth the $200?
This video is bs I asked the guy for the boost charts and they show 2-3psi less boost with the BOV. The 28hp is from the octane booster. The car is still advancing time between the two dyno runs. Not saying the BOV is bad but this claim is complete bulls***.
I dont agree. I will prove it. Ill do a before and after pull the next time I go to the dyno.
The octane booster will not do s***!!!
My Synapse BPV is on its way . . . I am planning on doing a before and after on my stock motor . . . We'll see who gets it done first :p
I don't know how you can say it doesnt do s*** when the second dyno showed it gained 27 whp between the first and second run. Have you seen the before and after boost charts the car lost 2psi of boost with new bov. Looking forward to seeing your dyno. I like this bov but think a 28 hp gain is bs.
Call Ken at pg he will set you up.
Ps. there is no way you loose boost with the valve. Mine gained 2psi.
I just watched the video. Whats so hard to believe. The dumbass owner probably put 87 octane it and the octane booster put it back to around 91. I bet money my car will dyno over 290whp now going from forge to synapse. With the forge on stock boost 280whp is what I saw. The most boost I seen with the forge was 15-16psi in 4th gear on the dyno. Now Im getting 18psi when I punch it at 3k in 4th gear. s*** I might even hit 300whp now on stock boost. Fack it Im going to the dyno tomorrow. Peace. I need to crush the hype and prove it works.
Went in the mail today, they made sure it went is as a gift. I'll shoot you the tracking number here in a minute.
Looking forward to seeing your results 311! I'd like to believe the vid......seems like an easy & inexpensive solution for high gains.
+1. I think my bov is leaking and if your dyno shows what you say it will I will have to consider the synapse. Does it sound stock when in recirc? I don't want a loud bov
I also think my bov is leaking.....question though....since i always worked on mustangs Im a complete retard when it comes to turbo.....does replacing BOV require any tuninng?
