Swap ECU's?
haha AbbyVonNormal, i made a wrong turn while following you home. instead of heading north i went south for a gude 5 min. that sucked
but anyway, glad to hear the ecu and filter helped.. kinda makes me wanna switch chips now
edit: maybe you could get it dyno'd at the next meet to see how big of a difference it really made
hehe..i saw you going forward when i made the right. I flashed my lights to try and warn you...but i guess it was too late!!
Glad to see you made it home OK!! :D
I live in south brunswick... I only live about 20 minutes from hooters, and about 10 minutes from where the train started
damn man i told you we could have picked you up. me and kooldino came up from rt 130 right thru your area:rolleyes:
yea i know, i had to work on the camaro though, i was gonna bring that, but I couldnt get it working in time, I had to swap the carb, because it was too big it was just dumping gas into the engine and fowling plugs, thats was easy, then we had to change the oil/change the plugs, and the lower radiator hose was leaking too, sh*t happens :mad:
AbbyVonNormal did you have to reset your ecu after the swap?
Also my ECU might be up for grabs, unless i get a piggyback that can controll timing b4 i get my turbo.
the piggy im going to show you at the run will interface and control the ignition and fuel no matter which ecu your running.
I'm still looking for a MP3 ecu myself. I am in the Chicago are and willing to drive to met you.
nope...i did not have to reset. Was plug-n-play!
The ECU was reset as soon as I pulled it out of the harness...
Hmm, I'm getting all jealous now. Anyone wanna swap a stock P5 ECU (mine) so I can try out an MP3 ECU? try it for like a month or 2?
PaulMP3, how 'bout you?
KzA said:
Hey ProFiz~!!! I ready for a swap!
Hey, are you going to the next meet on June 21st?? If not, if you still want to do the swap, i'll come down to Toms River whenever to do the swap... let me know
Yea man I should DEF be going to that meet...im actually going to make a new thread bout it right now..
