well.. if his valve cover is already in decent shape, then he dosen't need to sand it(unless he want's that polished look of course). Aircraft remover dissolves the paint so it can be wiped/washed off.patmaz said:if you do a little search,on POLISHED VALVE COVER,you should find the how-to,there is a tread about it,you need to sand it,with different grain sandpaper,a bit of work,but worth it....or you also have the option of getting it sandblasted,wich would give you the choice of painting it the color you need
sephiroth said:well.. if his valve cover is already in decent shape, then he dosen't need to sand it(unless he want's that polished look of course). Aircraft remover dissolves the paint so it can be wiped/washed off.
Black_Protege_5 said:Aircraft remover is awesome. But it doesn't taste very good. Make sure your mouth is closed and nothing gets in.
defentaly do not swallow any, otherwise poision controll will be needed. (nailbyt)o. Mouth went numb for a little but I didn't swallow any.
You can get it at any auto store. I get mine from Pepboys.
azeli73 said:Found it.
http://www.spaceagepaint.com/product_detail.aspx?id_product=3340
This place is about 5 miles from me. Thanks!
I plan to get the valve cover powder coated black to match my pipes once it's stripped.
http://www.mazdas247.com/members/azeli73/April24th2005/13.jpg
Nightmare said:lol..
brake fluid
