Sorry, I forgot. I'm on 2 hours sleep and 5 cups of coffee.
Is it bad that everything looks orange?:wtf:
The silver peice snaps loose but not off.
It comes of enough to use a screw driver to take out a metal bar that is between the pocket and radio. #2 phillips on each side. This metal is what makes the radio opening into a din for the radio and one for the pocket.
Take the radio out first. You need the screw to do it. I can't remember there size. Do a search for it, I believe linuxracer posted the size. I will try to find it and put that in my sticky info thread.
Once the long thin removal screws are in you just have to pull like hell.
You may need to drop the glove box and get a hand behind the radio to free up the monsterous wiring harness adapter mazda used. I buy another one from scosche or metra also.
Once out you can take out the screws on the metal bar, remove the bar and then the cage.
then just get a good hold on the pocket and pull real hard.
