steering wheel
hookah
CX-9
my steering wheel is bending to the right when I go straight, actually since I bought it :'(
now it's a little bit more and I want to but it straight.
can anybody tell me how to remove the cover with the airbag? do I have to take care of anything?
or shall I pass this issue to the service people at mazda??
this is a known issue in 2007/early 2008 models, it has its own TSB,
just take it to the dealer and tell them to check the related TSB
thx blue_omg, I have this TSB but actually my baby is 2009. so it's the same issue? or let's say I can complain regarding/against this known TSB and they will do it free of charge??
I think you two are talking about different issues.
The issue of 2007 is about wrong strut fitment that caused the vehicle to drift to one side on highways.
The fix was to rotate the strut properly. Problem solved. Not applicable to later models.
I believe this was probably a production line problem.
The OP seems (to me) was talking about the steering wheel not at center when going straight.
This is an alignment issue. A simple wheel alignment should fix this.
Removing the cover of airbag does not fix it properly.
