?Startup Issues - WTF?
Kooldino
MOTM Winner Jan '09
Authorized Vendor
Contributor
MP3
Ok, so out of nowhere I started getting some startup issues.
It happens on occasion, at what seems to be complete random.
As soon as I turn the key into the "on" position, I hear a "pop", something like how a vac line sounds when it pops off.
Then I go to turn the key, and the car won't start.
After trying several times, the car will start, but it will die instantly. However, if I hold the throttle, all is well. A:F ratio is stoich. But the moment I let it go, it will die again.
If I turn it over, keep my foot on the throttle for a few minutes, and let it warm up, it will eventually behave like normal and drive fine.
I've checked all of the vaccum lines, and it all seems fine. I'm at a total loss right now.
I plan on checking my spark wires tonight, and beyond that, if it happens again, I'll check the connections on my MPI.
Any other suggestions?
Came up with a possible idea...PCV valve? Seems like I've been getting a lot of blowby through my crank case vent on the side...maybe the PCV isn't working correctly?
Could be a thing to check out, a lot of blow by isn't normal. At least I don't think it is.
peepsalot said:
If it's PCV, supposedly you just shake it to tell if it's good. rattling PCV = good
That's what I hear. I'll have to shake dat ass before I leave work.
Would a PCV valve cause a running issue though? What would explain the pop then? The PCV valve doesn't "do anything" when the key is flipped...
This is true. I just thought I'd check it out due to the blow by I've been getting.
The pop totally baffles me. It's not super loud though. just sounds like pressure being released.
Any funny smells? Gas? Can you hear the fuel pump pressurize?
Maybe a pop like a spark arcing as soon as power is distributed?
Ok, so after inspecting the area around my throttle body, I came to the conclusion that something looked like it was missing. I assume it was just a bolt, so I threw one in there. Anyone wanna double check for me? Maybe this was a contributing factor? Either way, it's good to have the bolt back in there. :)
peepsalot said:
well did it fix your problem?
Well, it only happens at random, so I dunno. I got like 5 good starts after the clusterfuck today, and that was before i replaced the bolt.
seriously sounds like your PCV valve.
i forgot to put mine back in after working on the car the other day and it had the EXACT same symptoms as yours.
i have the Millenia PCV valve now.. dunno if that makes a diff or anything in performance, but it sounds like your PCV valve is faulty or something.
I took that out yesterday and jiggled it around. Seemed fine. I too, have the Millenia valve.
Anyway, it fired up the second I breated on the key this morning. So I guess we'll see.
How often did it make the "pop" noise? If once, maybe that "pop" was that bolt saying c-ya...
It could have been, but doubtful. Apparently the VICS opens when you turn the key to "on", so maybe it flipped and leaked air out of that spot in the IM?
Ok...so today during lunch, I went out.
Put the key in, turned it to the on position...heard the quiet "pop"...oh crap.
Tried to turn it over, and it didn't want to start. I stayed on it for 6 or so seconds and it fired up...and then immediately died.
I popped the hood, opened and closed the VICS actuator (didn't seem abnormal).
Got back in the car, and it fired right up. WTF?
