started my perrin fmic install
msp03.5
2003.5 Madzdaspeed protege
Decided I would tackle it today. I am taking my time so I hope to have it up and running by sat.
here is the start
first time taking off bumper not too bad
Now I am at my stopping point before work OH ? for you guys what do I do with the stock bpv there is a vac hose comming off it where do I put this on the bov? or what thanks in advance and yes I am a NOOB!lol
As far as I know they are legal. They are the lamin-x covers my cars on there showcase for the yellows. I got them cause I wanted something different not too many people like em but eh well I do. Oh thanks for the good luck cause I am sure I will need it lol.
Notorious_V.I.C said:
Do you really need to jack the car up for a FMIC install? Just askin...and where did you get your hood pins?9
Ummm not sure if you have to but I like working on it like this. plus I am going to do an oil change. The hood pins are just some APC pins I got from checkers they are actual hood pins not just the display kind that make it look like there in In case you were wondering.
Ok so this thing is pissing me off the piping does not want to fit. I am about to cut off some of the piping from the pipe that connects to the throttle to make it fit ahhh. Does anyone know if that would be a bad idea cause of the lip on the end of the piping or would it be fine? anyone else run into this problem?
Ok won't cut piping thanks cause I was about to lol. why is it bad? is it cause the lips at the end serve as a blocker so the couplers don't slide off? just wondering.
here is the pipe it seems like it is too long. I unbolted the fmic and hooked up the piping but it would not match back up it gapped out so the support beam would not mate up. I feel like I have tried everything but it is just giving me hell.
Any suggestions would be greatly appreciated.
thanks in advance
albert
Ummm, I'm looking for my pictures for reference....but I didnt have any problems with the piping been too long...I did have a problem with it been to far to the left...where I had to trim the metal more than suggested. Then the pipe fitted and that allowed the core to be more centered than it originally did.
Edit....well this are the only two pics I found and its obvious that they dont help too much...but if you see where the silicone coupler is, then you might be able to compare it with yours.
uh oh im planning on installing my perrin front mount tomorrow er uh today. sure hope i dont run into that problem. good luck on that.
thanks for getting back pirana I appreciate it and for the pics. I am going to go at it again today. I will use your pics for ref. on my cuts also how far down did you move the ac condensor ( I think thats what its called).
albert
thanks. Hopefully you don't its sucky. But I am a noob so that probably has something to do with it lol.
