squeeky rear beshings
eszoom
eszoom
blk protege es
hi all, my question is when replacing the rear sway or stabilizing bar bushings with new ones, do you just slap it on or grease them first?
thanks, rod
Yes, you will want to lube the bushings first. White lithium grease or marine grease work quite well.
Take some rough sand paper and sand the sway bar where they sit and throw some grease there too. It will keep it there and help keep them lubricated for longer
Pretty much. It's only held on by the 2 brackets that go around the bushings and the 2 end links. I would look into replacing the end links while you're there
thanks, tweety, i was hoping i didn't have to take off the bar. i'm afraid the endlinks will be frozen or rusted. befor i do this i better have new end links. anybody else try to do this without taking off the bar?
It's not possible, at least one of the links have to be removed. It will be easier to remove them both. Cut the old ones off and put the new ones on. You will have to do it eventually anyway and now is the best time
you should not HAVE to remove the bar to replace the bushings - at least, not in the rear. also, you can just wrap the bar with 1-2 turns of teflon plumbers tape under the bushing. the teflon tape is much less messy, and will last much longer than any grease you stuff in there.
The OP was asking only about replacing the rear swaybar bushings, in which case the endlinks do not have to be removed.
the sway bar bushings have cuts in them already (well 99.3% of them do) so it is super easy to unbolt the bracket, pull the old bushing off, new bushing, then bracket.
The energy suspension grease-able bushing + bracket is a great upgrade. Did it on my '03 and my clunk is completely gone.
ok, i changed both rear bushings and it still clunks. what i did was clean and wrapped some electrical tape on the bar. shot the inside of the bushing with white lithium grease. tighten everything up. what went wrong? next day off i"ll shoot lithium on the outside of the bushing between that and the bracket, and if that don't work, change the sway bar links which i thought i could get away with, haha.
I bought mine from Mazda and they didn't have a cut in them
after changing the bushings and end links, it was the strut making the clunk. thanks all, for the help.
