Splash Shield Hardware
2012 MZ5 Sport
I'm looking for hardware to properly secure the splash shield on my 2012 MZ5.
I've finally located the main part (which the parts sites call an "under cover" CG15-56-110A), but have no real reference for what fasteners to order, given that my splash shield has been previously attached with various screws and bolts run right through the shield and into another plastic brace.
Anyone have a generally intact splash shield they can provide some guidance on? According to the little diagram, I have a choice of these James Bond parts:
EDIT: For anyone looking for the parts and quantities they are:
  • Under Cover Screw (9CF6-00-516B) - 4
  • Under Cover Bolt (9KDB-00-620) - 7
  • Under Cover Fastener (GD7A-50-EA1) - 2
  • Guide Plate Screw (9YA4-10-615) - 4
  • Splash Shield Rivet (L33X-13-209) - 2
Go to Partsouq.com. Put in your VIN (very important). Then click on the diagram you need and get the part number.
For my 2010 MZ5, (I think it's probably the same for you) uses this diagram:
Take the part numbers and get the parts from an online discount Mazda Dealer. Or for small stuff, I just get it from my local dealer.
Ever considered going Junkyard hunting for those?
I tend to drop misc fasteners in my toolbox whenever I go to U-Pull-It type junkyards while I removing other required parts.
I haven't heard of Partsouq before, I'll check it out. Thanks!
EDIT: Wow okay, this site is awesome. Its everything I wish the parts dealers would do. So easy to find what I need.
I definitely should have done this, smart!
I might settle on this if it ends up having the same bits that I find I end up needing.
Thanks everyone!
