speaker sizes
jay3338
i was wondering what size spekers icould put in the four doors and what kind of trouble id run into if ibought alpiin type r 6.5 or if they would fit with ease
Speakers are 6.5" components in the front and 6.5" in the rear doors.
The Type-Rs will fit but be sure to check the clearance with the window. I would also NOT recommend changing out your speakers unless they are blown. Reason being, the Alpine Type-R speakers are very power hungry and will not sound good without an amp.
Type-S speakers are good. But I would still go with the Type-R and an amp. Much better clarity and a better cross-over.
Those speakers are actually intended for a multi-component system using crossovers and multiple drivers. You can hook them up, but due to the lack of a tweeter you will have very muddy, if any, high frequency response.
Also, Wagonbacker would be right, Lanzar aren't the highest quality products out there. Spend a bit more to get a name brand coaxial speaker and you will be much happier.
