Alot of potentially dangerous information in this thread for inexperienced MSP owners...
When in doubt, READ YOUR MANUAL! As mentioned, the MSP supplement clearly states the gap spec (0.028" to 0.031" I believe). You can assume this is designed for stock boost levels, and I would NEVER go wider...unless you go NA for some reason
In general, a narrower gap will be required for higher boost levels...to a point. Too narrow and you will not have enough spark to burn the AF mix efficiently.
You can safely run the stock plugs at stock boost (go figure). Copper plugs will be more tolerant of higher boost levels due to the electrode construction...larger and less chance for hot spots leading to detonation. Copper plugs should also be checked and replaced more frequently...not a problem since they're so damn easy to get to in our car.
A step cooler heat range will also be helpful for detonation resistance at higher-than-stock boost levels. A '7' heat range will remove more heat from the tip than a '6' range and so on. Again, too much isn't necessarily a good thing.
With respect to modding and tuning cars, everyone has to start somewhere. Don't be afraid to take it slow until you understand what you are doing. Get help from more experienced people you trust (preferably not on a message board
). If you want more information on spark plugs in general...there is good technical reading at NGKs website.
Peace...(hippy)
