New '05 SP23 owner. Does anyone know if you can tweak the bass on the actual sub, or only through the HU? I had a '97 Maxima SE with the Bose system, no sub, and I could pull a lot more bass out of that system by tweaking the HU control than I can this unit...it's pretty weak. Also, the specs on the car say that the amp is programmable. Do I need to remove the plastic covering to see any controls? BTW..I am by no means an expert when it comes to this stuff.
Thanks
Thanks
