Sp20 awd help!!!
autozam
2000 Familia ES
Looking for someone from our other country members who has seen owned or know of the 1998-2002 SP20 awd model protgs. I need to know if the awd rear sub frame is close to or same to or totally different from the BG rear subs. If newer lateral links and suspension sway bars etc.. from a SP20 model would bolt up to the older BG sub frame. I have a BG rear. trying to make as close as possible to a newer SP20. I can get the awd to work no issues. Just trying to find out if I can use newer suspension or if have to use old suspension set up. Thank you if you reply. I have tried searching for pics of BJ rear sub. and part numbers. But we are limited here in north America even when you work at mazda like I do.
