Sound from dvd source
Kauai Dave
'07 Nissan Titan!
Okay so i just bought a screen that i plan to mount in my car. and i was thinking of using my playstation to play things off of. i bought a power inverter also. the question is how do i get sound out of the play station on to my car deck and or speakers? any help would be great! =)
what kind of deck do you have? generally if aftermarket, they'll either have, or you can get rca-inputs for them. THen you simply plug in the red and white RCA's of your playstation to the corresponding jacks on the back of your deck. THis will be your "aux" source.
most low end aftermarket decks don't have an aux. in. higher end units have them. or the ability to be added on like some pioneer models do. another option is an fm mudulater wich will run inline with your antenna lead and youlle basically tune your radio to a certain radio station dial and it will pick up the sound from your ps2
you can get an fm modulator that will allow you to recieve the signal as an fm signal on a channel usually 85.9 or another channel. the run on ebay for like 30 bucks.. but bewarem usually they give bad sound as the grounding on these things can suck.. so it is really hit and miss.. either it will sound great or like crap. Hope this helps
-AcTs
What head unit do you have?
Any alpine Ai-net, (M-bus might be able, but I don't recall) headunit has the ability to use an adapter that turns the CD changer bus into an aux input. Its a $15 part. Many pioneers are the same way.
