oil tap into pan.. the 1.6l's pan goes striaght onto the block, unlike the 2.0l with the center piece in between the block and the pan... anywho.. i took off the pan today to tap in to it, and realized o s*** .. there is some kind of oil shield around the crank shaft.. my question is , is it ok if i cut a small section out of it so that the nut wont hit it ?? as long as my crank shaft doesnt hit it, i should be fine right?
