someone..ANYONE! please help me!
The running like s*** part could just be your ecu adjuting its self my car runs like utter dog s*** for about 100 miles untill its done
yes actually i just did its now just giving me P0300: multiple cylinder misfire and P0505: idle air control system malfunction an it just feel real weak an just sitting still while its idling it just kind of shakes a bit and stays below 1k rpm
And clean the IAC valve, that could be the 505 code.....if the IAC isn't broke. Hopefully it's just dirty. Might wanna go ahead and clean the egr if the IAC is dirty because that can make it run like s*** too and mine threw no codes when it was doing it, just made car die when stopped at light. 300 is gonna be coils plugs wires or combo of the 3. +2 on not driving with misfire codes...........
changed the plugs,coils,and cables and still same thing it just feels like it wants to turn off it idles at around 500.how exactly do you clean the iac?
if you have gapped the plug correctly and you have clean the iac, then move on the EGR and MAF. at this point we suggest that you use the search feature avail on the top right side and the how to section.
i havnt drove it much just from parking spot to the garage in the back.bear with me here i dont know how to "gap" the plugs or reset the ecu sorry ill try the search bar there now tho
yea hopefully after i gap the plugs and clean the iac the misfire goes away..do you think thats something i can do myself im no dummie with a good how-to im sure i can pull it off but if it not that then on to the egr and maf it is. And im not sure how to reset the ecu but ill google that now lol.hang in there boys we almost there
If you want to try the egr valve i got my old one around i replaced it but turned out it didnt need it so the other still works hit me up if you wana try it.
if it wasnt your egr what was it?..and i cant find anything on cleaning iac or egr? And as far as ive read..to reset the ecu you unplug the ground\negative and hold the brake for like two minutes then wait a few more before plugging it back in is this true.
that should do it. if all of your radio presets are gone then you are successful...!
