Bass Addict said:
Wake, does the dynamat really make that big of a difference, in your opinion?
it all depends on where you put it
for testing purposes i removed my rear door panels and played a 30 hz sine wave through my 18. talk about rattles. it sounded like ass. painted the drivers door with the elemental designs paint on dampener and the passenger door with the cascade paste dampener, and no more sheet metal rattle. but now you can hear the window trim on the outside vibrate and the entire door push out and rattle. i'm going to put in some weather stripping for the whole door, and i need to take the window trim off and resecure it. on the doors the dampening made a huge difference. on my floor it made almost no difference. the 2 layers on my roof helped to keep it from vibrating, but IMHO was not worth the effort. concentrate on the doors and trunk quarter panels. removing the rear bumper and dampening that helps a ton, if your bumper shakes like mine did. also replacing the 2 plastic fasteners on the bottom side of the rear bumper with bolts, nuts, and washers secured the bumper sooooooooooo much better. for the trunk lid, in the open voids i used expanding foam, and for the thinner areas i used 2 layers of dynamat extreme. the trunk lid still jumped up almost 1/2 an inch, so i put in some 3/4" foam at the bottom edge to hold it tight.
does dynamat make a big difference, yes, as long as you put it where it is necessary. but keep in mind that many rattles can be fixed with some weather stripping for $2 rather than $100 worth of mat
just as a note, with my car running, but only getting about 13 volts input to my amp (bad protege charging system that can't keep up), here are my various SPLs at different freq's:
20 hz = 130.35
30 hz = 133.96
40 hz = 138.67
50 hz = 131.22
60 hz = 137.46
70 hz = 131.95
i'm currently using an ABC enclosure so it peaks a little under 30 hz and a little under 60 hz. the spike at 40 hz is from where my bass cube was boosted at for daily driving. i'm going to equalize it out so that the response is flatter tomorrow. it's nice having so much adjustment from my 30 band EQ
