So please
christiansMSP
2003 MSP
Someone give me the steps to put on springs... I know I need a spring compressor and all.. But what steps do I have to take.. This is my first time doing anything suspension related.. Thanks!
simply, remove stuff off of strut, like the brake line, remove strut mount, pull out strut, compress spring, take off strut mount, take off spring, compress spring to put on, put on strut mount attach put strut back on and all hardware, tighten down on bolts on top for strut mount on strut and strut mount on car. done with number 1. rinse lather repeat
Cause the sping has enough stored energy to kill you.
Jeg wrote a how to. Please read it in the how to section before touching your car.
A shortcut I have always done
Car on ground loosen big nut on each strut (front/rears) and just jack it up to de-compress the springs.
Then unbolt the strut from the hub and endlink to swap springs.
Replace by guiding the strut in with an allen wrench in the strut shaft from under the hood/or in trunk
ive done springs 3 times on my car and never used a spring compressor. theres not much tension with our springs
i want to do rears my self tomorrow.. but do i really need a sc?
first step. go into trunk loosen up strut?
second. jack up rear.
third. replace spring?
I've done over 20 cars and never used a spring compressor and still have all of my limbs doing it as described above :)
Rear deck cover? How couldn't I get to them from the trunk???
the strut tops are boxed in by the frame. only way to get to them is to fold the back seats down, remove the rear deck cover, then remove the seatbelts.
its all outlined pretty well in the service manual.
