So Cal Machine Shop willing to shave off....
EXA4DRIVER
04 Suzuka Blue S2000
a couple of mm off of the hub of my wheels?
Anybody in So Cal or in Cali in general that knows of a reputable machine shop that can modify wheels? Thanks for any info.
Contact Rishie, ARD_MP5....he is in San Jose....I bet he can give you some recommendations.
MC Motorsports in ontario california is a machine shop which specializes in wheel customization. I do know for a fact that various wheel manufacturers have use them for R&D as well as custom drillling and machining to create higher offsets. the number is 909/947-5115
Measure well, I had my KMC Suicide shave 5mm off the hub. Extremely satisfied with them. Make sure you get a good shop.
Hey Pirana,
How much did it cost and how much can they shave off with out damaging the wheel. I got a set of Gewalt Evolution II's for my 325i (19x8 front 19x9 rear 235/35/19 front and 265/30/19 rear). I got the an offset made for an M3 (+31) and the rears are rubbing even at stock height. I want to shave off at least 5 or 6mm so that I can finally lower the car.
Thanks,
Jay
WEll consider I own a couple of bimmers. And we just put 19's on it. hehe.
I could help answer the question.
It needs to be about 10mm higher. Therefore it's not plausible to machine that much pad off the wheel since the lugholes have already been drilled.
To do that in rear you should have run about a 40 or so.
Rishie
