- Mazda protege5
Well the wagon has been through allot over these past 5 years and s*** is starting to fall off so it's time to finally start a build to try and keep Ole Yeller going.
I'll start with the bad, the rear brakes are gone (calipers are seized and one side is actually missing a pad), struts and springs are toast, needs bushings EVERYWHERE, exhaust is ultra custom rust muffler delete (the muffler rotted off lol), engine mounts are all cracked out, engine is starting to smoke a good bit and transmission hasn't held fluid in 3 years. That being said I've driven it everyday for the past 5 years and it's taken a beating. (2 miles of haul roads everyday for 2 years probably didn't help), I'm pretty amazed this car is still running but it's sad to see the condition it's in and a little piece of me dies every time I hear another piece bouncing down the road behind me on the freeway.
So I've decided to finally start rebuilding, I'm going to start with an engine and trans, and then gather all the suspension goodies I can and hopefully I can do everything all at once and just take a week off to install everything.
My plan for the engine, I'm going to stay NA and keep it simple and reliable.
wiseco 11:1 custom pistons with side skirt coating
K1 Billet Forged Connecting Rods
FSZE Camshafts
DeatschWerks Fuel Injectors
awr 4-2-1 exhaust header
MP3 ECU Reflash
Mishimoto Radiator
Mishimoto Aluminum Fan and Shroud Kit*
fidanza lightweight flywheel
exedy stage one clutch kit
AWR engine mounts kit
Transmission is just getting a simple rebuild and either an msp or quaife limited slip
(1) Main shaft oil seal
(2) Axle oil seals
(1) Locking Nut (main shaft)
(1) Locking Nut (secondary)
(2) LSD bearings
(1) Lower Main shaft bearing
(1) Lower Secondary shaft bearing
(2) Upper shaft bearings (31.02 for both)
Oil pass channel
All (5) Synchros
(2) main/secondary shaft shims
(1) LSD shim
For suspension I want a mild track build that's still streetable
yellowspeed coilovers
626 front brakes 1993-2002 (2.5L) V6
v6 626 front calipers 1998 to 2002
v6 626 front caliper brackets
v6 front brake pads 1998 to 2002
rear calipers from a mazdaspeed protege
rear brake pads from a mazda6
msp rear brakes
Centric Posi Quiet Loaded Brake Calipers 142.45527 passenger side
Centric Posi Quiet Loaded Brake Calipers 142.45528I drivers side
msp 25mm front sway bar
AWR rear sway bar 21.5mm
AWR rear sway bar bushings polyurethane
AWR rear sway bar brackets 21.5mm
custom endlinks F/R
AWR bushing clamps
msp front strut tower brace
Megan Racing Trailing Arms
Megan Racing F&R Lateral Links
Mazdaspeed Racing Harts 17x7 +55
Yokohama 'S tires (I'm gunna try some firestone winter force for rallycross)
Arp extended studs ARP-100-7708 from summit racing
Braided Steel brake lines
gt spec trunk cage (forums for sale once in a blue moon)
So this is pretty much my plan of attack, most of this list will probably change seeing as I've never done anything this big before and don't really know my stuff, but hopefully at the end I will haha. I just picked a '97 626 engine to start tearing down, I've heard you can use the block but everything else will need to be swapped out with protege spec parts or it won't run quite right. Anyways I'm hoping you guys can help me out along the way and maybe this will eventually help someone else out. I will get pics when it's not dumping down rain.
(Edit) I revised my to do list for my budget and ocd(lol), I priced out allot of it and realized I'd be in my mid thirtys before I finished. Btw if anyone has part ideas or knows any info you wanna share feel free to fill up the comments [emoji6]🖒
FSZE Camshafts
MP3 ECU Reflash
Mishimoto Radiator
(2) Axle oil seals
(2) LSD bearings
Oil pass channel
All (5) Synchros
(1) LSD shim
msp rear brakes
custom endlinks F/R
AWR bushing clamps
