Sirius integration
NCGiant
2008 Mazda 6
Just bought an 08 Mazda 6 and have hit a roadblock adding Sirius. I have looked all over and keep finding the OEM tuner for about $300. I would prefer to buy a universal tuner and get an interface to work with the factory stereo. I can get a universal tuner for $80 but have not found an interface for it. Seems like there is one for every make except Mazda. Can anyone help me out?
Easy. Use AUX mod since it re-appeared in stock.
Or you can use something like that:
http://cgi.ebay.com/ebaymotors/2006...56QQitemZ150251858518QQptZCarQ5fAudioQ5fVideo
http://cgi.ebay.com/Mazda-AUX-IN-MP...emQQptZLH_DefaultDomain_3?hash=item518d5b6df1
It is expensive, but you additionally will get ability to use IPOD or USB stick. Note, you must check which one compatible with yours, it is just examples.
It has a line IN(AUX). I got XM Delphi SKYFI3, it fits in cavity in front of stick. You just need to remove 12V outlet from there and make a bigger hole for base cables. I had really bad ground noise and was forced to install ground loop filter.
