Sirius Antenna
Skywlkr
2007 Toyota 4Runner Sport
Has anyone loved the location of the sirius antenna? I just received my sharkfin antenna and have heard you can fit the sirius antenna under it. I was wonder what has to be done to get the antenna run through the extinting car antennas hole and onto the roof.
You have to drop the headliner out, remove a nut, pull out the stock piece, thread the Sirius wire in from the top, and close it up.
Not too bad of a job, be careful with the headliner.
I drilled out a little area on the bolt for the antenna so it didn't pinch the wire and I also put a little silicone there. All in all its pretty easy but be very careful with your headliner.
you can fit both the stock radio antenna AND the Sirius antenna? how big is this shark fin?
The sharkfin replaces the stock antenna and the shell is large enough to fit the sirius antenna under it. You can do a search in the 6 forums and their is a thread with pictures.
