You can get more out of the car by side gaping the plugs.
( http://performanceunlimited.com/documents/plugsidegapping.html )
( http://www.angelfire.com/me4/dugbugwap/images/SplugMod.JPG )
I have used these in a 03 Protege DX.
I used ZFR6F-11 like that & the BKR6EK types
but the BKR6E-11 are the best and safe!
The spark goes to the ground as it is the closest before the piston! It will not hit the piston! That is why I don't use the ZFR plugs, just to make sure! So stock with mods!
The BKR5E-11 "5" heat range are too hot for my engine.
I would not use the iridium spark plugs etc.
A power line is not a small wire!
You need the volume of spark, not a 1mm spark to set
off the fuel!
Also worth it is to index the plugs.
Facing the intake where the fuel is the closest.
There are other options for poweryou can tie down
your ViCS & VTCS,
all wide open! It hisses massively! MadMax!
Sounds like a V8, kind of, not like a cow mooing!
And you get more in the mid, low end, high!
( http://home.dbdbdugbug.operaunite.com/photo_sharing/content/ALL PHOTOS/MAZDA-STUFF )
off the fuel!
your ViCS & VTCS,
