- Mazda 6 iTouring 6MT
I love this cx5 but I assume it will be hard to find the original owner, its posted almost every other day on instagramIs this anyone's? I'm sprung and have found my inspiration.
Sent from my iPhone using Tapatalk
curious what "wobble nuts" are? Can you explain?Thanks. They will be unique. They were $355(!), they are replicas, but still.
They will look even better, with the Corksport springs installed.
Will need to get wobble nuts and locking nut kit, which are not cheap($120).
I have picked up these 20"-ers. Color will change.
Any ideas on how should I paint them?
Think outside of the box.
I'm thinking, black spokes with red "lip".
https://www.dropbox.com/s/ka0lagnuw1rs1mz/securedownload.jpg?dl=0
https://www.dropbox.com/s/y43nrh1ikmgf1d5/securedownload (1).jpg?dl=0
Here is a picture, with some wobble nuts (they are bolt too):
http://www.serpentautosport.com/varinuts_edited-1.jpg
The conical "washer" has a much bigger diameter, then the nut's diameter and allows to shift to one side.
This way it will compensate for a bigger/smaller bolt pattern.
I'm installing an Audi 5x112 bolt pattern wheel, on our car's 5x114.3 bolt pattern.
This one is played out?
I don't see why they would not be safe.
Think like you have a bigger hole washer and you shift it to one side and tighten down the nut on it. That "washer" is conical in shape and it will seat in the wheels conical surface, it's just shifted a bit(~1 MM) to one side. Center hub bore is holding the wheels, precisely in the center.
The nuts are not centering the wheel at all.
The conical surface(which matters) sits completely in the wheels conical surface(100% touching each other). The bolt/nut is off center, by ~1 MM(~0.040"), that is nothing. I don't see anything wrong with this.
Just got the winters installed.
