Should I roll fenders to fit wider tire
protege5peed
mazda protege 5
Just put some 16x7 konig incidents with 205/55r-16 hankook k407. I am having a problem with my rear fenders rubbing. I like the look but i dont want to tear up my tires, Also does anyone know the rating or the milage on these tires Ive searched but had no luck finding info
Did you get them at a local shop? If so, they gave you a wheel w/too low of an offset, and too tall of a side wall. I'd go back there and make 'em switch them out for a combo that fits- especially if they recommended that combo. You need something like a +42 offset or higher, and a 205/50-16 tire. Don't roll your fenders unless it's a last resort.
I've been reconsidering moving to 17 inch rims. I'm leaning toward 16x7 like you have. But 205/55r16 is too tall. With the x7 rims, consider going 215/45. Almost an inch wider than stock with the exact same diameter, so no error in the speedo.
Doug
Actually 205/40/17's have the same diameter as the stock 195/50/16's, so with 215/45's there will be a slight error in the speedo, but no big deal.
I'd try to get a wheels with a higher offset. I know for a fact that 205/55/16's will fit on the stock P5 wheels because my friend had to put one of those on his car a few weeks ago when he had a blowout. And his car is lowered with s-techs. Your offset is just too far out. Probably a +42 or +45 would make it ok.
