Shock Upgrades For A 2024 CX-5 Carbon Turbo?
We just got a 2024 CX-5 turbo carbon with 4k dealer CEO miles on it. The Toyo A36 tires truly sucked, so we put a set of Pirelli Scorpion WeatherActive tires, which makes it feel like a different car. It had a dangerous level of reactiveness to center lines and a jitteriness with bumps and road irregularities. The tires have made a remarkable difference in smoothness, noise, and stability, but there is still a slight tendency for it to follow pavement cracks and lines.
I can only assume this leaves shocks that are not doing as good a job as they could be, and was wondering if any other CX-5 owners have noticed this and found shocks that are smoother. I'm thinking this has to do with an orientation towards performance that shocks with different valving might be smoother.
There are few options.
Bilstein B6 will be 10% stiffer than OE.
KYB is supposedly the OEM.
I'm not aware of any others.
Other than that, there are complete coilover assemblies from B&C Racing and Ceika. These have adjustable damping and it's possible you could tune them down to be softer than stock. I have yet to see anyone actually report doing that, though.
on my 2023 cx5 turbo I can go no hands on the steering wheel at any speed and straight arrow down the road it does not follow imperfections and was the same with the stock toyos which I replaced at around 25000 miles and the Michelin CC2 which I have had for the last 15000 miles or so... I would have the alignment checked..
What I'm wondering is if the shocks on the Carbon are different than the preferred and preferred plus, I keep seeing references to something that indicates a performance upgrade. With the Toyos this thing would rip the wheel out of your hands passing cars when you hit the center line under acceleration. If this is the case I am going to "downgrade" from the Carbon shocks...this sucks right now, although it is way less than it was with the Toyos.
So you think it could be alignment, or perhaps steering parts that are performance oriented?
I think your shocks/struts are the same as every other turbo regardless of year or model..looking at part numbers they are the same. my understanding is the color is what essentially differs the carbon edition and different style wheels. nothing performance wise.
could be an alignment thing... shock absorber differences between specs/grades are not surprising... manufacturers typically do this to match up with weight/options equipped in a car, but also sometimes because of a "sport" version or different engine
if I had access to the latest dealer parts catalog, I can tell you for certain lol
but, any stock mazda, they handle pretty good but still leaves a lot to be desired when you push them hard... bilstein shocks will definitely be an upgrade, and so will bigger sway bars and stiffer springs (at a cost of comfort)
