ScanGauge II Xgauge Programming
Speedy3
Contributor
2007 Cosmic Blue MS3
To Read Actual Boost (Intake Manifold psi-Approximated Atmospheric psi (14.5)):
TXD:07E0010B
RXF:0441850B0000
RXD:2808
MTH:000A0001FC18 KPa (Subtracts 100kPa from a mode 01 MAP reading)
MTH: 00910064FF6F psi (Converts to psi)
Anyone knows anymore, please post in this thread. Specifically, I'd like to know how to program a AFR Xgauge. So far, the ford or GM versions don't work.
ScanGauge Xgauge resources here:
http://www.scangauge.com/support/xgauge.shtml
Have you tried the o2 sensor input codes listed on their site yet? If so, what does the gauge show for those values? I'm thinking about getting one for my Protege, but if all it shows me is the o2 sensors' voltage readings, and not the afr's, then I'll pass on it.
Here is the atmospheric BARO CAN code if anyone knows how to use it. I'd like to get the scangauge to subtract atmospheric pressure rather than a fixed number for a boost xgauge.
135765ms REQ MSG: ISO15765 00 00 07 DF 01 33
135775ms TX MSG: 170906usec ISO15765 00 00 07 DF 01 33
135795ms RX MSG: 170907usec ISO15765 00 00 07 E8 41 33 61
135975ms BARO = 97 kPa
